In the summit evolution software, draw only 2d point hight (z value) in the MicroStation v8 but using the summit evolution software the below options are set manually in the software. and then I will pick any point on the map it should move to 3d point hight. So kindly suggest any solution on how to automatically enable the option of the "DAT.EM button manager" setting in the MicroStation software programmatically using VBA.
DAT/EM Button manager=> System Mouse configuration=> then choose the Type is as “Plotter” and Action is as “Align”,
I do not know DAT.EM button manager you mentioned, but I assume it's not Bentley Systems software? So I assume you should ask support of the software producer?
MicroStation VBA is a tool to access and control MicroStation, not other software.
With regards,
Jan
Some more notes:
Be aware this is general Developer and Programming forum, whereas you question is about MicroStation. So I recommend to move your post to MicroStation Programming forum. To move existing post to another forum (never duplicates the post!), use More > Move tool under your original post.
Also, please read and respect the best practices! There is a recommended subject format and a standard set of information that has to be always specified like product and exact version.
I see you add some tags, but you specified both MicroStation and Bentley Map (two different products) and V8 version as well as MicroStation Connect, which btw is completely wrong, because such versions do not exist. There can be 8.0, 8.1, 8.5 etc. or CONNEC Edition Update <number>. Plus it's not clear what do you mean BentleyConnect, because no such thing exists.To provide such information is confusing and it's not clear what product and version do you use.
