I see a new phenomenon which never happened to me before. Cells sometimes lose all nested cells in them. It is puzzling.
I copied a cell library which I wanted to update from the network to a folder in the local drive. Then I attached the cell library on the local folder and edited some cells. I then copied the cell library back it to the network location. When I load MicroStation I see that some cells have lost all the nested cells. If I attach the cell library on the local drive it is fine. The size and modified date of both the cell libraries are exactly the same, Something happens to the cell library when copied to another location. Does anyone know what the issue is?
Dilip Bhandarkar
Hi Dilip.
please respect the community best practices and do not ask twice for the same topic in different forums (like you did, this is completely the same question)! It's confusing and annoying, because it's not clear what thread is the main one :-(
When a question is placed into wrong forum, More > Move tool has to be used to move existing discussion to another location. But never asked again for the same at different place.
And even when it happens, it's a good habit to make a note in wrongly placed question to do not answer such question and to provide a link to the correct one.
With regards,
Jan
Please cancel my subscription as I have retired.
