Dear All,
I am working with microstation v8 2004 Edition and VBA. i want to read the ODBC Data linkage value from attribute column. Here i attached the screenshot for better understanding.
Please any one give suggestion for get this value.
Thanks & Regards,
Karthik M
Hi Karthik,
database linkages are stored as attribute data, attached to an element.
It's recommended to use DatabaseLink object to work with this data, because API hides internal complexity of attribute data format.
When you need direct access to user data (e.g. because you need access something else than DB linkage), see User Attribute Example in MicroStation VBA help to understand how to do it. But this way is complex, because raw data are retrieved and has to be interpreted using knowledge of internal structure.
With regards,
Jan
Hi Jan,
Thanks for your quick response. I got the solution thank you so much.
Thanks and Regards,
one more note: Be aware you posted your question to general Developers and Programming forum (which is not so active and is very common). When you issue relates to MicroStation API or programming, you should always use specialized MicroStation Programming forum.
hi,
Jan Šlegr said:you should always use specialized MicroStation Programming forum.
Ya sure jan , I will follow your comments.
