In Connect structure
struct { UInt32 keepOriginal:1; UInt32 splitOnly:1; UInt32 direction:2; UInt32 depthMode:2; UInt32 local:1; UInt32 lockDepth:1; UInt32 smartFeatureProfile:2; UInt32 reserved:23; T_Adouble depth; } cut;
inside SmartSolidSettings I think there is an error, The bitfield total size is 33. I think it should be 32 (reserved size should be 22 and not 23). In v8i SS4 the same structure is defined as:
struct {#if !defined (BITFIELDS_REVERSED) UInt32 keepOriginal:1; UInt32 splitOnly:1; UInt32 direction:2; UInt32 depthMode:2; UInt32 local:1; UInt32 lockDepth:1; UInt32 reserved:24;#else UInt32 reserved:24; UInt32 lockDepth:1; UInt32 local:1; UInt32 depthMode:2; UInt32 direction:2; UInt32 splitOnly:1; UInt32 keepOriginal:1;#endif double depth; } cut;
I suppose that this error should be corrected asap as it introduces an offset in this structure (and implicit in MS3DToolSettings & PersistentTcb structures)
Yes, this is an issue we will investigate this further.
Paul
I do not think its is proper to let spam in this forum. Besides I still wait an answer as it concerns opening v8i files in connect edition. Some information stored in the persistent Tcb can be lost.
