I´m Alejandro, frontend developer in Nexplore, and I would like to know if therer are some tools that replace Holebase SI extension, in order to integrate it with angular or maybe if there is some way to integrate Holebase SI extension with angular framework.
Also, if it is possible are all versions supported?
Thank you very much in advance.
Cheer.s
I guess you should get it from youtube.
