Hello All,
I created some cones by MVBA codes below:
Sub TestCone() Dim MySmartSolid As SmartSolidElement Dim MyTrans As Transform3d Set MySmartSolid = SmartSolid.CreateCone(Nothing, 2, 5, 10) ActiveModelReference.AddElement MySmartSolid With MyTrans .RowX = Point3dFromXYZ(0, -1, 0) .RowY = Point3dFromXYZ(0, 0, 1) .RowZ = Point3dFromXYZ(1, 0, 0) .TranslationX = 10 End With MySmartSolid.Transform MyTrans MySmartSolid.Color = 3 ActiveModelReference.AddElement MySmartSolid End Sub
The first cone is the black one. then I revised transform, the second cone is red one. I'd like to know how to calculate RowX/Y/Z if I'd like to move it to the yellow one, assuming I know the coordinates of the two centers. Thanks a lot.
I have tested and please find below the VBA code I have put together to transform one such a SmartSolid to the exact position of another Smartsolid with the same definition.I have attached a small dgn file containing 2 SmartSolid elements. The green one I am using as source to transform to the position of the other (red) Smartsolid.
I have used some steps to calculate the rotation of each Smartsolid and combine the required transformations to get from the position of the one SmartSolid to the other SmartSolid.
There will be a lot of different approaches to get this done....
For more information on this topic please see:Transforms
I hope this helps?
Best regards,
Artur
Sub transFormTest() ' the idea is to transform the source element to the position of the target element ' The 2 SmartSolid elements to get the rotation from: Dim oSource As SmartSolidElement Dim oTarget As SmartSolidElement Set oSource = ActiveModelReference.GetElementByID(DLongFromString("1400")) Set oTarget = ActiveModelReference.GetElementByID(DLongFromString("1408")) Dim x As Double Dim y As Double Dim z As Double Dim oph As PropertyHandler Set oph = CreatePropertyHandler(oSource) 'Calculate rotation of the Source element: If oph.SelectByAccessString("RotationX") Then x = Val(oph.GetValue) Dim s1 As Matrix3d s1 = Matrix3dFromAxisAndRotationAngle(0, Pi * x / 180) If oph.SelectByAccessString("RotationY") Then y = Val(oph.GetValue) Dim s2 As Matrix3d s2 = Matrix3dFromAxisAndRotationAngle(1, Pi * y / 180) If oph.SelectByAccessString("RotationZ") Then z = Val(oph.GetValue) Dim s3 As Matrix3d s3 = Matrix3dFromAxisAndRotationAngle(2, Pi * z / 180) Dim s As Matrix3d s = Matrix3dFromMatrix3dTimesMatrix3dTimesMatrix3d(s1, s2, s3) Dim sInv As Matrix3d sInv = Matrix3dInverse(s) Dim sTrans As Transform3d ' this transformation describes to unrotate oSource: sTrans = Transform3dFromMatrix3dAndFixedPoint3d(sInv, oSource.Origin) 'Calculate rotation of Target element: Set oph = CreatePropertyHandler(oTarget) If oph.SelectByAccessString("RotationX") Then x = Val(oph.GetValue) Dim t1 As Matrix3d t1 = Matrix3dFromAxisAndRotationAngle(0, Pi * x / 180) If oph.SelectByAccessString("RotationY") Then y = Val(oph.GetValue) Dim t2 As Matrix3d t2 = Matrix3dFromAxisAndRotationAngle(1, Pi * y / 180) If oph.SelectByAccessString("RotationZ") Then z = Val(oph.GetValue) Dim t3 As Matrix3d t3 = Matrix3dFromAxisAndRotationAngle(2, Pi * z / 180) Dim t As Matrix3d t = Matrix3dFromMatrix3dTimesMatrix3dTimesMatrix3d(t1, t2, t3) t = Matrix3dFromMatrix3dTimesMatrix3d(t, sInv) ' Calculate transformation describing the translation from Source origin to target origin: Dim moveTrans As Transform3d moveTrans = Transform3dFromPoint3d(Point3dSubtract(oTarget.Origin, oSource.Origin)) Dim tTrans As Transform3d 'this describes the rotation ogf the target element tTrans = Transform3dFromMatrix3dAndFixedPoint3d(t, oSource.Origin) 'combine rotation with translation to one single translation: tTrans = Transform3dFromTransform3dTimesTransform3d(moveTrans, tTrans) 'Transform source element to target element oSource.Transform tTrans oSource.Rewrite End Sub
3835.transformation.dgn
Hello Artur,
Maybe I didn't express myself clearly, my purpose is to rotate the source element to any place which does not exist yet. So I cannot get the dest element and copy the rotation from it.
My understanding about the transform3d/matrix is, the RowX/Y/Z means the coordinates of the new transform3d/matrix's X/Y/Z in the WCS, but I failed to calculate the new coordinates as per the transform3d/matrix. I will study the PDF file.
Thanks a lot!
Changsong Ling said:my purpose is to rotate the source element to any place
I've written an introduction to rotation and transformation for programmers.
