Need to Understand 2D Cell Rotation Angle When Cell is Mirrored About the Y-axis
Hi All,
I have a program that needs to unrotate a 2D cell to 0 deg/no reflection which has been placed at any rotation angle and/or mirrored about the X- and/or Y-axis.
Specifically, the problem I'm having is when the cell has been mirrored about the Y-axis, mdlRMatrix_toAngle () returns a rotation angle of 180 deg from the cell's rotation matrix, which causes the cell to be unrotated by and incorrect angle.  mdlTMatrix_containsReflection () (get tMatrix from rMatrix) does return TRUE which does indicate the mirroring. When the cell is unrotated by the inverse of its rMatrix, it get a 180 deg rotation that messes up it orientation.
Is there some way to couple the 180 rotation angle and contains reflection mirroring information to properly unrotate the cell?
 LCell 2D Rotation.dgn
Warren
v8i SS10, VS2005, W10
