We are looking to drive the use of Plaxis 2D to run an analysis and export results back to a neutral format or us to post analyse a structure. I'm looking to use console to drive this, and it looks as if this is possible through the standard DOS running method. https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45947/launch-plaxis-2d-calculations-via-dos-commands
However, to get the results out, I can see us using the tabulate command, but have no way of printing the tabulated data to a file? Is the command line data saved somewhere in the .pd2x file that we can access? Or is there a way of exporting the results by launching a python script from the command runner?
I would appreciate thoughts on this and if anyone has any ideas of how to get around this it would be greatly appreicated.
Tom
