We are are porting a set of MDL applications from MS V8i SS10 to MS CONNECT Update 14.
This includes the set of mdlCntr_xxx MDl functions, which are available in the V8i API, but not in the MS CONNECT MicroStationAPI. At a first glance I couldn't find any adequate set of functions.
So question is: What to use instead ?
As far as i know mdlCntr essentially is a list or a map. Is that the way we have to go ?
Any hints or pointers are appreciated.
Thanks in advance
Martin
Hi Martin,
be aware this is general Developers and Programming Forum, not specifically MicroStation. I recommend to move your question to MicroStation Programming Forum. To move existing post, use More > Move tool available under your original post.
With regards,
Jan
