Hi all.
I'm working in a project that needs to handle the DGN v8 format. I want to download the SDK but I can't find it. I tried several ways I found but they didn't work. Can someone help me?
Thank you so much!
Nang
Hi Nang,
at first, please be aware this is general Developers and Programming Forum. Because your question is about MicroStation SDK, I recommend to move the discussion to MicroStation Programming Forum.
To move existing post, use More > Move tool available under your original post. Please, do not duplicate the post.
Nang Ngo said:I tried several ways I found but they didn't work.
Because MicroStation V8i is product with expired or expiring support (depending on version), only the latest V8i version, without SDK, is available for download.
To obtain SDK from Bentley, except you have to be BDN member, you have to create Service Ticket for support, who is able to process your request. Also, exact version of used MicroStation V8i is necessary, because for every V8i version, specific SDK version was released.
With regards,
Jan
