Hi all,
I am running into trouble with the increase of stiffness in the Mohr-Coulomb Material Model.
The increase in stiffness in the Model is linear, while my stiffness is parabolic. Is there a way to adapt a parabolic change into the Mohr-Coulomb Model or is there a Material Model where the stiffness can change in parabolically over the depth?
Thank you for your time
Jesco
Hi Jesco,
be aware this is general Developers and Programming Forum. I recommend to follow the best practices and to specify what product and version do you use. In your question there is no information about that. It seems your question is not about writing code, but it probably belongs to some product forum.
To move existing discussion to another forum, use More > Move tool available under your original post.
With regards,
Jan
Answer Verified By: Robert Hook
Hi Jesco Lange,
Per Jan's suggestion I see you Created a New post (vs suggested More > Move) in the correct PLAXIS-SOILVISION Forum. Given that and I will mark this issue as Answered and link the New post for convenience to the solution.
Refer to related Information/Response in these Posts:
Thank you and HTH,Bob
