I start microstation whith options -WKworkspace1 -WWmyworkset -WAmyprog dgnfilepath or -WKworkspace2 -WWmyworkset -WAmyprog dgnfilepath
The final user don't want the microstation dialog for choosing the workspace:
If i first open my file on workspace1 and then in workspace2, the second time the user need to confirm the file workspace.
Is it a solution in C# or C++ to force the file workspace to be the microstation active workspace?
if if put MS_SUPPRESS_FILE_WORKSET_ASSOCIATION = 1 in my cfg file, the file always open in the same workspace without message. I need file always open in microstation workspace without message.
Seb
the vba solution of glhouck seems to work
https://communities.bentley.com/products/microstation/f/microstation-forum/214380/is-there-really-only-one-option-for-the-workset-mismatch-alert-dialog/658711#658711
