I am moving a team to OpenRoads Designer (10.09) and I've been asked to implement an in-application "wizard" to replace the standard File > New functionality. Rather than have users manually key in the new DGN filename from scratch, I'd like to have a VBA form that allows them to select various controls that will build the filename for them based on the type of design file, discipline, etc.
I know some DOTs and other agencies have developed enhanced new file creation applets/add-ons using the SDK. Unfortunately, I haven't used C# in years and would have to invest a lot more time/effort than I would if I could perform the same functionality with VBA.
My question is whether this functionality is possible/recommended with VBA when connected to ProjectWise. I have found the CreateDesignFile() method that seems to be the answer, but I need to know whether creating new DGN files this way will:
Thank you very much for any guidance you can provide.
