I am trying to to develop a plugin for MicroStation with .net framework, following this tutorial :
https://communities.bentley.com/products/programming/microstation_programming/w/wiki/52303/introduction-and-prerequisite
I have those installed on my PC:
Visual Studio Community 2019 16.9.31205.134
MicroStation Connect Edition 10.16.0.80
MicroStation Connect Edition SDK 10.16.00.084
However when I try to create a new project in visual studio, there is no option relative to Bentley or Microstation.
Is there anything missing in my configuration ?
Thanks in advance
I found the answer myself :
In addition to what is listed in the tutorial, I need to install the extension "VS 2019Tools for MicroStation CONNECT Edition", which can be found in the extension market inside VS.
Hope that helps.
Cheers
Answer Verified By: Jiayi LI
