I'm developing new addins to a system (+20 years old) and I need to handle with some old MDL which I don't have the code. This system also interact with Oracle and others systems, so I'm not even thinking to redo the entire system. I also don't have access to the developer (and the source code).
I do not need to change the original code, just send and receive data from it. From some VBA codes I can identify some C expressions, which is used in Get/SetCExpressionValue, but I don't have all of them.
Is there a way to list all C Expressions avalible for some MDL application?
because your question is about MicroStation and this is general Developers and Programming forum, I recommend to move the question to MicroStation Programming Forum. To move existing discussion to another forum, use More > Move tool, available under your original post. Please do not ask again, but move the question.
I also recommend to read the best practices and to share more details like used product and its exact version, because now it's confusing a bit: You mentioned "old MDL", which can be both some from very old DGN V7 generation (like MicroStation/J) or some V8 version. But, at the same time, you tagged your question as "connect".
Old applications, developed for pre-CONNECT versions, do not work in CE environment (because of 32bit to 64bit migration, new changed API and different compilers), so situation is different when you stay at V8 (MDL application runs fine) or you plan to move to CE (everything must be ported and recompiled).
With regards,
Jan
