I need to convert ellipses with different Primary and Secondary Axis to multiple arcs with the same Primary and Secondary Axis. In Microstation I can do that using Facet tool but I need to achive the same result doing it programatically.
After conversion there are multiple arcs with same primary and secondary axis. Is there a way to do that programatically?
PS: If there is a way to do that using C++ it would be also usefull.
Regards, Damian H.
