[VBA] Assign Spatial Locations for DWG
There is an issue when extracting spatial extents from DWG files using attached MVBA scanning Project. This module works correctly in Microstation but not when used from spatial location scanning tool. It reports an unknown error and stops when scanning DWG files. How to debug it as it is running as background process and no results can be seen.
CustomExtract_MBR.mvba
