Element.AsShapeElement.IsSolid returning true always.
So I thougth the first subfeature shape always was the exterior and the rest of the subfeature shapes would be interiors --Wrong !!
So how do I find out which one is the outer perimeter and which are inner ??
TIA
Erik
Hi,the vba object model contains the property .IsHole, applicable to specific element types like shapes, ellipses, complex shapes and closed elements.
To give you an idea how to scan the elements within the active model, here a small vba example:
Sub HoleSolid() Dim ee As ElementEnumerator Set ee = ActiveModelReference.GraphicalElementCache.Scan Do While ee.MoveNext Debug.Print ee.Current.Type Call CheckSubElements(ee.Current) Loop End Sub Sub CheckSubElements(ele As element) Dim ee As ElementEnumerator If ele.IsComplexShapeElement Then If ele.AsComplexShapeElement.IsHole Then Debug.Print ele.FilePosition & " is hole" Else Debug.Print ele.FilePosition & " is solid" End If Else If ele.IsComplexElement Then Set ee = ele.AsComplexElement.GetSubElements Do While ee.MoveNext Call CheckSubElements(ee.Current) Loop End If End If End SubThis example works fine for complex structures represented as type 2 groups. Please post an example drawing file, if this doesn´t help in your case.Best regards,Artur
Hi
Artur,
Thanks for your answer. Yes it is correct that in for instance in a GroupHole Cell-element, one can read the Solid flag.
But withthe new Polygon_Collection element this is not helping, because here all the shapes (simpel shapes or complex shapes) have the solid flag set to Solid , see the included illustation below. Note that the inner shape in the building has solid set to solid
The Polygon_collection element (elementType 106) is attached to the root feature and contains no geometry, since all the shapes in the Pollygon_collection are attached as subfeatures to the root feature containing the polygon element.
I have attached a small bit of technical map with some building on, so you can test. You need to open it in Bentley Map I Guess :-Exampel_Polygon_Collections.dgn
