Hi Folks,
I have mvba code to apply a coordinate system to a folder of files. I am puzzled between RESULTS of the legacy V7-8 code and what I've used in v8i before.
Legacy code (abbreviated)
CadInputQueue.SendCommand "DIALOG OPENFILE " CadInputQueue.SendCommand "Gcoord Master Edit " CadInputQueue.SendCommand "Gcoord Master Read Ascii " CadInputQueue.SendCommand "MDL COMMAND MGDSHOOK,fileList_setFileNameCmd gda94-55.g66"
V8i (Out-Of-The-Box)
CadInputQueue.SendCommand "GEOCOORDINATE ASSIGN REPROJECT EPSG:28355"
Q. Can anyone explain whether these are the same result and if so, why they look different?
The V8 methodology came from PowerMap V7/V8 Geo days. Perhaps the later is all that is now required. I am not sure whether I am missing something fundamentally obvious here...
Cheers, Colin
Sebastien Cote
Answer Verified By: cweber
