V8i C# SS3 - Is it possible to extract the category of feature configured in GSA
All,
I have configured categories in GSA for all features and below is one of the example
Is it possible to retrieve the category name of a feature configured in GSA using C#? I have tried IStorageImportCriteria and IClassImportCriteria but could not find the category information.
  • Hello,
    try it with the xft.
    using Bentley.Interop.Xft;
    FeatureMgr mngr = new FeatureMgr();
    var defee = mngr.GetFeatureDefs(true, true);
    while (defee.MoveNext())
      string category = defee.Current.CategoryName;
    HTH
    Martin
  • Thanks Martin. Worked like a charm.
    I was able to get the information from class definition using below code but I think the solution provided by you is much cleaner and better.
    IList<Bentley.ECObjects.Instance.IECInstance> currFeatureInstances = currentClassImp.ClassDefinition.GetCustomAttributeList();
    foreach (Bentley.ECObjects.Instance.IECInstance iecInstance in currFeatureInstances)
    if(iecInstance.ClassDefinition.Name == "ECXfm")
    string featureCategory = iecInstance.GetPropertyValue("XfmCategory").NativeValue.ToString();
    break;
