v8iss3, vba programming - place point at regular interval on linear elements...
HI  all,
I want tp place points(place active point) along linestrings and shape elements at given interval. I made the below code, it works but not that fine, takes lot of time also dgn file goes hanging...
can someone tell me how can i improve this one? or is this the way this should done? I am a beginner in this area....
'place points at given interval along the linear elements...
'for example if the given interval is 2, then for every 2m a point should be placed on the linestring string from 2 distance...
Private Sub cbPlacePoint_Click()
Dim ee As ElementEnumerator
Dim ele As Element
Dim totCnt As Long, idx As Long, stDis As Double, ptInt As Double, leng As Double
Dim pnt As Point3d
'read interval from the user input
ptInt = tbInterval.Text
'check for input elements selection
If ActiveModelReference.AnyElementsSelected = False Then
MsgBox "Select linear elements and try again.", vbInformation
Exit Sub
End If
On Error GoTo out
Set ee = ActiveModelReference.GetSelectedElements
totCnt = UBound(ee.BuildArrayFromContents) + 1
idx = 0
ee.Reset
'takes the length of the linear elements to repeat point placing....
Do While ee.MoveNext
Set ele = ee.Current
'start point distance also same as interval distance...
stDis = ptInt
If ele.IsLineElement Or ele.IsShapeElement Or ele.IsComplexShapeElement Or ele.IsComplexStringElement Then
If ele.IsLineElement Then
leng = ele.AsLineElement.Length
ElseIf ele.IsShapeElement Then
leng = ele.AsShapeElement.Perimeter
ElseIf ele.IsComplexShapeElement Then
leng = ele.AsComplexShapeElement.Perimeter
ElseIf ele.IsComplexStringElement Then
leng = ele.AsComplexStringElement.Length
End If
'loop until start distance exceeds the length...
Do While stDis < leng
pnt = ele.AsLineElement.PointAtDistance(stDis)
With CadInputQueue
.SendCommand "PLACE POINT"
.SendDataPoint pnt, 1
.SendReset
End With
CommandState.StartDefaultCommand
stDis = stDis + ptInt
Loop
End If
idx = idx + 1
ShowCommand "placing points at interval"
ShowStatus "processing...." & idx & "/" & totCnt
Loop
ShowCommand ""
ShowStatus ""
CommandState.LastView.Redraw
Me.Hide
MsgBox "completed", vbInformation
out:
MsgBox Err.Description, vbCritical, "Error"
End Sub
Thanks in advance...
  • Hello,
    it is faster to create the LineElement per code than per Command:
        Dim ele As Element
        Dim pnt As Point3d
        Dim line As LineElement
            Exit Sub
        End If
        On Error GoTo out
        idx = 0
        ee.Reset
            stDis = ptInt
                End If
                    Set line = CreateLineElement2(Nothing, pnt, pnt)
                    ActiveModelReference.AddElement line
                Loop
            End If
            idx = idx + 1
        Loop
        ShowCommand ""
        ShowStatus ""
        Me.Hide
        Exit Sub
    out:
    HTH
    Martin
