[V8i SS4 VBA or C#] How to get a elevation from a Terrain Model for a specific point
Hi
Bentley Map SS4 has included a Terrain model (As far as I have understood it is the version from InRoad SS3).
Now I like to be able to utilize elevations from a Terrain model in VBA applications, how do I do that ?
I have to wishes:
1. Get the elevation for a given Northing and Easting
2. Having at straight line, getting the intersect points with triangle sides in the terrain mode
So where to begin.
Any help will be appreciated.
Erik Wirring
LE34
Denmark
  • Okay No answers ! Even not from any Bentley folks
    So the only solution I can see, is to export the Terrain model to LandXML. Create a C++ or C# application that reads the LandXML file, create the the triangle,edge and point data structure and do the Z-interpolation in that.
    This document "www.cs.uu.nl/.../TINalg.pdf" include description of data structure for storing TIN and a strategy ("jump and walk") to identify the actual triangle or edge.
    But I find it strange that there functionality available fro Bentley !
    Erik Wirring
    LE34
    Denmark
