Dear all,
I am using Microstation V8 2004 Edition, I draw two lines in the DGN the two lines startpoint is same but the end point is different and i am checking the angle of the two lines is same how its become same angle please give me the solution.
Here i attached the dgn please find it.
Karthik M
angleCheck.dgn
We can not see " how you checked the angle"?
Please check you angle unit settings, within that dgn!
Frank
Unknown said:hi, please select the line and see the information its showing the angle and the line length.
Information?? Do you mean "element information" command from basic Microstation? Have you checked the angle units settings from this DGN file? The both lines closing angle is 0.45......° The angle units precision is set to 0 (zero) in your DGN file settings. So you can not see what you are looking for! You see angle 0°. And please be precise when asking such questions and give some more information to get comprehensive help.
This was a basic Microstation question nothing realtling to Geospatial programming, right? You will better use this http://communities.bentley.com/products/microstation/ forum for a larger audience!
