Hi All!
I would like to develop MDL C++ Add-In-s (using the MircrostationAPI) for the OpenCities Map PowerView (update_6) - version 10.6.0.5.
I've installed the application.
I've found the following SDK: OpenCities Map CONNECT Edition SDK x64 Update 6 (English) --- https://softwaredownloads.bentley.com/en/ProductDetails/1941?buildid=20790
I tried to install but the installer fails with an error message. It says the OpenCities Map software is not installed. That's true.
I've found an SDK for Microstation also: MicroStation CONNECT Edition SDK x64 (English) --- https://softwaredownloads.bentley.com/en/ProductDetails/1000?buildid=18564
But I'm not sure if this is the right version to use?
I'm also not sure which Visual Studio version to use.
This site sasy I should use VS2015: http://www.la-solutions.co.uk/content/CONNECT/MicroStationAPI/VizStudio.htm
What do you think?
Thanks in advance.
Br
Miklos
Hi Miklos,
because your question is about OpenCities Map, I recommend to move it to Geospatial Programming forum. As you can expect, MicroStation development specialist are not necessarily familiar with geospatial products. To move existing post, use More > Move tool under your original post.
Miklos Bodi said:I would like to develop MDL C++ Add-In-s
In my opinion you are mixing different terms, which leads to a confusing information:
Miklos Bodi said:I tried to install but the installer fails with an error message. It says the OpenCities Map software is not installed.
Miklos Bodi said:But I'm not sure if this is the right version to use?
It's explicitly written in SDK information:
The SDK requires installation of OpenCities Map CONNECT Edition Update 6 and MicroStation CONNECT Edition Update 14 SDK. OpenCities Map is a Mapping software for editing, analysis, and management of 2D/3D geospatial information. Learn more about OpenCities Map versions here.
Miklos Bodi said:I'm also not sure which Visual Studio version to use.
The required Visual Studio version is always defined in PowerPlatform (MicroStation) SDK readme, on which a particular product (OpenCities Map) is based.
Because OpenCities Map CE Update 6 is based on PowerPlatform CE Update 14, you can check MicroStation CE SDK readme that Visual Studio 2017 Professional is required to compile native code applications.
Miklos Bodi said:This site sasy I should use VS2015
It does not tell anything like this, because it does not focus on Bentley Map / OpenCities Map product line, but on MicroStation only.
With regards,
Jan
Answer Verified By: Miklos Bodi
One more comment:
The product dependency is also available at the download page:
Hi Jan!
Thanks for your detailed clarification. That helped me a lot.
Br,
