Hi All!
I'm working on an OpenCities Map MDL (C++) Application. I have an old code, which has been operating under Bentley V8i, and now I'm migrating it to Bentley CONNECT EDITION.
I would like to automatically update a View when it is opened by the user.
Under Bentley V8i there was this callback
mdlView_setFunction (UPDATE_POST, func_viewUpdate );
Now I switched that to this one
ViewCallback::SetUpdatePostFunction(func_viewUpdate);
The problem is, that the new callback is never called.
Under Bentley V8i the callback is called when I open a View in the application and then I can update it.
Under OpenCities Map Connect Edition the callback is not called.
Could you help me what am I doing wrong?
I tried to handle the WINDOW_SHOWEVENT in my window event handler callback, but I got constant errors and struggling with it.
Br,
Miklos Bodi
Greetings Miklos,
Would you be able to provide test cases with source code demonstrating Bentley Map V8i expected behavior and unexpected behavior on OpenCities Map CONNECT Edition platform? Please feel free to direct message me for a secure upload location if necessary.
Jeff Bielefeld [Bentley]
Hi Jeff,
Thanks for your response. First I would like to describe again what I want to achieve so I made a screen shot of the application.
When I click on the button surrounded with the red circle (at the bottom of the picture) a window pops up (named: View 1, Default). Before the windows appears I want to update it. I want to refresh what to draw inside the window.
I've made a simple program which demonstrates how I try to achieve this.
Here it is:
#include <Mstn\MdlApi\MdlApi.h>static int func_viewUpdate( bool preUpdate, /* => TRUE if called before update */ DgnPlatform::DgnDrawMode eraseMode, /* => display mode */ DgnModelRefListP modelRefList, /* => files involved in update */ int numberRegions, /* => number of regions */ Asynch_update_view regions[], /* => region descriptions */ ViewContextP context, /* => view context */ int numCovers[], /* => cover list sizes */ MSDisplayDescr *displayDescr[] /* => display descriptors */){ mdlDialog_openInfoBox(L"view update test message"); return true;}extern "C" DLLEXPORT void MdlMain( int argc, /* => number of args in next array */ WCharCP argv[] /* => array of cmd line arguments */){ ViewCallback::SetUpdatePostFunction(func_viewUpdate); //in old Bentley code I used this callback, but it is not working any more //mdlView_setFunction (UPDATE_POST, func_viewUpdate );}
I want to update the content of the View in "func_viewUpdate" function.
I call "ViewCallback::SetUpdatePostFunction(func_viewUpdate);" inside MdlMain and I reckon that my callback should be called. But it is not called at all ever.
When I was developing plugins for Bentley V8i I used "mdlView_setFunction (UPDATE_POST, func_viewUpdate );" callback. After I registered my callback under V8i my callback handler was called before the window appeared and I could update the View.
Miklos
Miklos,
Using the provided information, I've duplicated the behavior described for MicroStation V8i and confirmed that UPDATE_POST events are triggered after a view is opened and the view updates.
In MicroStation CE the behavior I observed is that your func_viewUpdate function is being called only after a view update (e.g. refresh, zoom in/out etc...) event occurs, but not after a view is opened which is inconsistent with MicroStation V8i behavior. I would suggest you file a service request with your findings to have the issue further investigated.
func_viewUpdate
As a temporary workaround, you might try registering a window modify event callback using...
...with function similar to...
...which should be called when a view is opened.
Thanks for your response. I will go on with this workaround.
We found that in V8i if you clicked on the Wiew Area button on the View toolbar, the above callback is triggered. However it is not called in CE.
Could you recommend another workaround for that case? I think the windowModify events are not appropriate for that?
I've also filled a support ticket about this issue.
