All,
I have used the following code to query features with in a fence
BGU.IImportCriteria criteria; BGU.IStorageImportCriteria storageImp;criteria = GDI.GeoDataInterchangeAddIn.Instance.MasterFileImport;if (criteria == null) return;// Set spatial filter criteria. criteria.Geometry = null;// Set Spatial Area Criteriacriteria.SpatialArea = BGU.SpatialArea.Fence;storageImp = criteria.StorageImports[0] as BGU.IStorageImportCriteria; if (storageImp == null) return;BGU.IClassImportCriteria classImp = storageImp.ClassImports as BGU.IClassImportCriteria;if (classImp != null) classImp.Selected = true; GDI.GeoDataInterchangeAddIn.Instance.ImportOrExport(criteria, null, true, true);
return;
// Set Spatial Area
In most cases this code works fine but in some projects it is giving me error at the following line
// Execute the query. GDI.GeoDataInterchangeAddIn.Instance.ImportOrExport(criteria, null, true, true);
This is the exception
"An unhandled exception of type 'System.stackoverflowException' occured in Bentley.EngineeringContent.Storage.xfm.dll
As this is Stackoverflow exception I cannot handle it from c# code. I just need some help to analyze this error, does this happen If i try to query in more features or is this related to some other issues.
I really appreciate your time and help
