Not sure if this is the right place to ask.
How can i extract information in design file to a text file?The information involves all the elements in the file with its properties.I need to extract these information, without opening the file in Bentley Microstation.Is there any library available that i can use for achieving this programmatically using DotNet.
why do you duplicated your question already posted in MicroStation Programming forum? If you need to work with data created in some geospatial product, this is the right place. If you are interested in a plain dgn file, MicroStation Programming forum is the right place.
With regards,
Jan
