I'm attempting to extract EC-attributes from an AutoPLANT i-model. The sample model i'm using can be downloaded from this link:
http://download.nois.no/isycad/Outgoing/autoplant_test_autoplant_schema.dwg.i.zip
This file contain only a single element, and have attributes of the type Piping Component.
I'm using the following code to extract EC-attributes, this code works fine with i-models created in MicroStation.
void attributesFromECAttribute(MSElementDescr *ElDscr, DgnModelRefP modelRef) { ElementRef elemRef; UInt32 filePos; BXN::StringListHandle slHandle; // init businessdata WString rootName("_"); Bentley::XMLInstanceAPI::Native::XmlInstanceStatus iStatus; Bentley::XMLInstanceAPI::Native::XmlInstanceApi apiRef(GetAPI(iStatus)); // read elementRef filePos = mdlElmdscr_getFilePos(ElDscr); elemRef = mdlModelRef_getElementRef(modelRef, filePos); // read the EC attributes slHandle = apiRef.ReadInstances(iStatus,elemRef); // nr of attributes int count = slHandle.GetCount(); // return 0 elements on the AutoPLANT sample model }
Reg.
Bjørn Egil Jenssen
Hi Bej,
Please note that some Plant files store ECXAttributes not directly on actual graphical element, but on NamedGroup element it is associated with. So you can firstly get its associated NamedGrp elemRef by calling mdlNamedGroup_findGroupsContaining and then get ECXAttr from that grpElRef. The following message is my test result:
HTH, YongAn
