[Connect update 4] Issue with TextStyle
My system is windows 7, VS 2015
I find Text Style Height and Width behavior very strange and here is example.
I have created TextNode with multiline text. With each new line, font height and width is different.
Debug.Print Application.ActiveSettings.TextStyle.Width prints result zero when clearly width is 10
Then I change width and Height to 20 and result is strange as picture shows.
dgn file is attached.
VBA code:
     Debug.Print Application.ActiveSettings.TextStyle.Name
     Debug.Print Application.ActiveSettings.TextStyle.Height
     Application.ActiveSettings.TextStyle.Height = 20
     Application.ActiveSettings.TextStyle.Width = 20
           Dim nTxt As TextNodeElement
            Set nTxt = Application.CreateTextNodeElement2(Nothing, Point3dFromXYZ(0, 0, 0), Matrix3dIdentity)
            nTxt.AddTextLine ("test1")
            ActiveModelReference.AddElement nTxt
          Dim oPH As PropertyHandler
          Set oPH = Application.CreatePropertyHandler(nTxt)
          oPH.SelectByAccessString ("ViewDependent")
          oPH.SetValue (False)
5344.test.dgn
Any idea?
best regards
Nenad
