Can I make sure the value of the parameter "MS_DWGSAVEAPPLICATIONDATA = 0 is kept for the user each time he enters Microstation. I wasn't able to achieve that.
Is there a way to control the parameter automatically, for example by running a recorded macro. I wasn't t able to record this type of macro. Is there a way to do that using vba code?
Unknown said:Can I make sure the value of the parameter "MS_DWGSAVEAPPLICATIONDATA = 0 is kept for the user each time he enters MicroStation?
MS_DWGSAVEAPPLICATIONDATA is a MicroStation configuration variable. You specify configuration variables in one of MicroStation's configuration files. Configuration files are plain text files. Most have the extension .cfg. Read about configuration in MicroStation help.
Unknown said:s there a way to control the parameter automatically
You can query and set a configuration file using MicroStation development languages, including VBA. ActiveWorkspace.AddConfigurationVariable and ActiveWorkspace.ConfigurationVariableValue do what you want.
Often CAD administrators need to lock a configuration variable, see: How to lock a configuration variable.Additional details for this variable can be found here: MicroStation CONNECT Edition Configuration Variables > DWG/DXF (Close-Specific)HTH,Bob
Hi Ido,
I guess it was answered by Jon and Bob already, so just a small comment:
Unknown said:the value of the parameter "MS_DWGSAVEAPPLICATIONDATA = 0
Accordingly to documentation the valiad values for this variable is ON and OFF, not 0. But I did not test it if 0 is processed as OFF regardless it's not described in documentation.
With regards,
Jan
Ido, My thoughts are you have a new (product based) question related to loss of information during a conversion that would be best asked to the appropriate product support team community first as a new post. If, the question is not able to be addressed and you are able to program to work-around/work past an issue providing a sample of what you currently have (dgn file, screen capt) showing what is expected and what is wrong (dgn and/or screen capt) we will be glad to provide any programming input and guidance we can. HTH, Bob
