In CONNECT, the ToggleIconRsc doesn't look "as good" as when used in MicroStation V8i. In V8i, when the ToggleIcon was depressed, you saw a slight "depression" and shadow line around the icon:
yet in CONNECT, I see this (blueish mask over whole image):
Also, in V8i, when raised, you saw this, with a slight raised edge:
however in CONNECT we get:
with no visible edges.
Is there any way to get a better representation between a raised and depressed ToggleIcon? Also, is there a way to change the blueish background applied when the ToggleIcon is depressed? It make the graphics harder to see.
Bruce
A colleague of mine has pointed me to the answer. The issue is related to the use of "Borderless Icons", as set in the Preferences. Once "un-checked", things look MUCH better. It never occurred to me to check the setting in Preferences. Thanks Bill Brown.
Answer Verified By: Bruce Reeves SRNS
