Sorry if this ends up being several questions. If I need to split it up into a couple of different threads, I can do that.
I'm trying to create an MDL app that will run in the background while the user has a .dgn open. That seems to work, if I add it to MS_DGNAPPS. I tried MS_INITAPPS, but I'm not trying to create a frontend, and couldn't figure out how to let it start my AddIn and then revert to the normal UI. Is there a way to have the addin register itself in MS_DGNAPPS? Or maybe that's part of the install process for the addin? Like adding a file to `MicroStation\config\appl`?
The addin should also be able to import models from a .dgn on disk into the open .dgn. I found this article,
And I'm starting to wonder if I offended someone - I've been trying to ask how to go about joining the BDN so we can get access to the SDKs, but all the instructions I got were for someone who was already connected to a company, and I am the one who has to go about setting up the company, and it's been taking two weeks to hear anything back. Really frustrating to be told something to do, not be able to do it, and have no way to go about making it so I can do it, and not getting replies back to my emails for over a week while trying to figure out the first step.
Unknown said: I've been trying to ask how to go about joining the BDN
Send an e-mail to bdn at bentley.com.
Unknown said: If I need to split it up into a couple of different threads
Start with the simplest question. Keep in mind that MicroStation CONNECT has direct support for C#, so you're not obliged to use the VBA (COM) interface. Consequently, the example you cite is not 21st century — it was probably written for MicroStation V8.
Hi Neil,
Unknown said:Sorry if this ends up being several questions. If I need to split it up into a couple of different threads, I can do that.
I agree with Jon it's better to start with separately discussed simple questions, on the other hand the starting more general discussion, that can help to evaluate basic ideas and directions, is not bad first step.
Unknown said:I'm trying to create an MDL app
It's a bit confusing terminology, because historicaly "MDL" was used as a name for different things, but I guess for the most of people "MDL" mean native code. In CONNECT Edition era "MDL" is used as a general naming for group of technologies or APIs that MicroStation offers. In my opinion it's better to explicitely use "MicroStation addin" or "managed code" if you plan to use C# and "native app" if C++ will be used.
Unknown said:that will run in the background while the user has a .dgn open
MicroStation has been event driven environment from early versions. So to use "run" is probably not the best word, because MicroStation applications (both managed addins and native applications) are loaded, but they not "run" for the most of the time, they are loaded and waiting to be activated by some event (key-in, internal command, MicroStation event etc.).
Unknown said:That seems to work, if I add it to MS_DGNAPPS ... Like adding a file to `MicroStation\config\appl`?
It seems there is a lack of knowledge how MicroStation variables works and also how MicroStation application works. I think you should split the development (and relevant discussions) into more steps:
Unknown said:The addin should also be able to import models from a .dgn on disk into the open .dgn.
To import a model from another deign file is a standard MicroStation feature. What is the reason to duplicate it?
With regards,
Jan
Unknown said:It seems there is a lack of knowledge how MicroStation variables works and also how MicroStation application works.
No argument here. I have been working through tutorials on Learn Server, but have a ways to go.
Unknown said:To import a model from another deign file is a standard MicroStation feature. What is the reason to duplicate it?
As I read your reply, I realize that perhaps a MicroStation addin is more than what I need to do in order to satisfy the requirements. Basically, we have a cloud storage platform that contains uploaded .dgn files and a separate design-environment-independent companion application. In response to the user making a choice in that application, I need to download the file to the local disk (not MicroStation-specific) and trigger the built-in, standard MicroStation model import feature on a running instance with an active .dgn file.
My original thought was to load an addin with a timer that would poll the other application for insert commands and execute them as it received them. But if there is a more MicroStation way to pass a standard command or keyin into a running instance of MicroStation, that would be even better, and wouldn't even have to be C#.
I was out of office for a few days, but now there is some time to return to the discussion ;-)
Unknown said:In response to the user making a choice in that application, I need to download the file to the local disk (not MicroStation-specific) and trigger the built-in, standard MicroStation model import feature on a running instance with an active .dgn file.
Based on you description I see two possible solutions:
