I am looking for MVBA objects/properties/methods that I can use to change the size of the Solids Working Area. I can change everything pertaining to working units with an MVBA macro except for the SWA Where do I look? I am running MicroStation 08.11.09.459.
there is no method in MVBA which allows changing the solid working area.
Best regards,Artur
