1. When including code in your post, please use the the SyntaxHighlighter, which is one of the tools in the "Advanced Reply Editor".
2. To let others know the MicroStation release and programming language being used without having to open the thread, please start the subject of your topic/thread with the following convention:
[<release> <update> <language>]
where <release> is:
and release <update> is similar to:
and API <language> is one of the following:
For example, if your inquiry is regarding the MicroStation C++ API in MicroStation 2023.0, your topic/thread should start with:
[2023.1 C++]
CONNECT Edition Update 12, your topic/thread should start with:
[CONNECT Update 12 C++], [CE U12 C++],...
If your inquiry is regarding MicroStation VBA in MicroStation V8i SELECTseries 3, your topic/thread should start with:
[V8i SELECTseries 3 VBA], [V8i SS3 VBA]...
3. If the issue you are encountering is specific to a product version or OS or computer, please include the following in your post:
