Hello
I'd like to detach ref files on dgn file indicated only by its name not opening it and calling mdlRefFile_detach func.
Is it possible to open dgn file in background with mdlWorkDgn_openFile func. and than call another one to detach all ref files
on selected dgn file .
Greg: I'd like to detach ref files on dgn file indicated only by its name not opening it and calling mdlRefFile_detach function. Is it possible to open dgn file in background with mdlWorkDgn_openFile function and then call another one to detach all ref files on selected dgn file.
The mdlRefFile_xxx functions all assume an active model reference. That is, there are no public functions such as these, which is what you would need to achieve your goal:
mdlRefFile_attachCoincident ( DgnModelRefP* outModelRefP, char const* refFileName, DgnModelRefP* hostP, ... ); mdlRefFile_detach ( DgnModelRefP refModelP, DgnModelRefP hostP );
If you can run your MDL as an MS_INITAPPS, then you could work on the active model without showing any graphics to your user.
That's it - perfect
I have a bad habit from MS V7
Tanks for Your fast reply and help
Regadrs
Greg
