How do you get a .java or .jmdl file to actually load in to microstation?
I mean, I can type in the command to load it, but where am I meant to store the file for it to be loaded?
Also, how or where do I look to try to get my program to interface with the create new layer function?
sramage: How do you get a .java or .jmdl file ...?
It really is not a good idea to develop using Java or MicroStation Java. Although many of us wept at Java's demise, MicroStation is firmly in the Microsoft camp these days. More comments about MicroStation Development Languages.
sramage: How do you get a .java or .jmdl file to actually load in to microstation? Where am I meant to store the file for it to be loaded?
The details are fuzzy (it's nearly 10 years since we stopped using Java), but doesn't the CLASSPATH environment variable play a key role with the Java run-time?
sramage: How or where do I look to try to get my program to interface with the create new layer function?
What is the create new layer function?
by create new layer function, I mean the fuction that runs when you hit the button to create a new layer of drawing.
Also, how would I go about learning MDL? I've tried in the past to find online tutorials, but to no avail.
When you "hit the button" in MicroStation's user interfave (or any product), that usually does not equate to "calling a function" in the API -- at least not on a one-to-one relationship. Typically, a "command" is called that invokes a series of functions and statements to fulfill what the user "clicks on" in the interface (or enters from the command line). You can get a good sense of this using MicroStation's VBA macro recorder. Although that might not result in exactly what you are looking for, you might at least get an idea as to what is happening behind the scenes.
AFA programming with MicroStation is concerned... there is the MicroStation SDK, which has some examples included. Have you looked at that? If not, that might be worthwhile to do.
sramage: How would I go about learning MDL?
That depends where in the world you are. If you are close to a Bentley office, you could contact the Bentley Institute to find out about training.
You need to be fluent in C/C++, as well as understanding MicroStation.
