i want to know this function mdlElmdscr_close (&pClosed, pOriginal, modelRef)
i cant understand the term &pClosed, pOriginal. please help me with simple example!
A closed element has an area (2D) and possibly a volume (3D). Examples of closed elements are polygons, ellipses and B-spline surfaces. Examples of open elements are line-strings and arcs.
An open element may appear closed. For example, a line-string having more than four vertices and coincident start and end points looks like a closed polygon but remains a line-string; an arc having a sweep angle of 360° may look like a circle or ellipse but remains an open element.
There's an article that shows how to determine whether an element is open or closed.
const BoolInt Erase = TRUE; MSElementDescr* pLine = NULL; MSElementDescr* pClosed = NULL; ... read line-string into memory if (SUCCESS == mdlElmdscr_close (&pClosed, pLine, modelRef)) { mdlElmdscr_add (pClosed); // Free memory mdlElmdscr_free (pClosed); // You may want to delete the line mdlElmdscr_undoableDelete (pLine, filePos, Erase); mdlElmdscr_free (pLine); }
can any one give me some suggestion to make a closed shape if the linestrings seems to be in shape but not in the shape.
Have you read the MDL help documentation for that function?
Unknown said: linestrings seems to be in shape but not in the shape
What, exactly, do you mean by that? As usual, a picture is worth 1,000 words. Why not post a small DGN model that illustrates 'seems to be in shape but not in the shape'.
here i ve attached a small example.. should i directly use the function mdlElmdscr_closeto make it shape or needs to do other things?
regards
cjan
Hi cjan,
in this case you should make use of the mdlRegion_floodFill - Function.
It automatically corrects overlappings and you are allowed to enter a closure tolerance.
This function is a prgrammatical call to the "Create Region"-Tool of the Microstation. (under Tools/Groups/Create Region).
Unknown said:Should I directly use the function mdlElmdscr_closeto make it a shape?
Surely it's quicker to add that function to your code than to post a question here?
MSElementDescr* pLine = NULL; DgnModelRefP modelRef = ... ... get line string and modelRef from somewhere MSElementDescr* pShape = NULL; if (SUCCESS == mdlElmdscr_close2 (&pShape, pLine, modelRef)) { mdlElmdscr_add (pShape); mdlElmdscr_display (pShape, NORMALDRAW); mdlElmdscr_freeAll (&pShape); }
A possible problem with your line-string is the zero-width portion. You might be able to create a shape, but it would be topologically invalid. That may or may not be an issue. If it is an issue, then adopt Stefan's suggestion.
the function mdlRegion_floodFill is not in my api file so i ve no idea about it. Can any1 suggest me to use this functions like its attributes and all.
Unknown said:The function mdlRegion_floodFill is not in my api file
Then you have not looked very hard.
Search for that function in the MDL Function Reference (see screenshot).
Do you notice Required Header <msregion.fdf>? That means you should #include <msregion.fdf> in your source code.
Have you looked in that header file?
Unknown said:I've no idea about it
Use text file-search techniques to locate function names in header files. There are a few programmer's text editors that provide file-search tools. Window's findstr can also be helpful.
i ve used the code as
if (SUCCESS == mdlElmdscr_close2 (&pShape, pLine, modelRef)) { // mdlElmdscr_add (pShape); // mdlElmdscr_display (pShape, NORMALDRAW); mdlElmdscr_freeAll (&pShape); }
but the line where i marked // is showing incompatible in shell. what is the problem? Please help me...
your code looks good.
What do you mean by "is showing incompatible"?
As I mentioned earlier mdlElmdscr_close2 will not solve your problem.
This function is only applicable when converting an even correct open element into a closed one.
But the line string in your example is not topologically correct. It contains doubled points and even a gap.
You wont get that closed with mdlElmdscr_close2, thus the function will not return SUCCESS for your example and the if-statement will not be computed.
Best regards,
Stefan.
P.S.
Do you speak spanish, by any chance? (Then you could send me spanish mails to stefan@centauron.de)
