Hi, There,
There seems to be only function to get the active model, i.g. mdlModelRef_getActive. How can I set a model active?
Any suggestion will be greatly appreciated.
Ken
mdlModelRef_activateAndDisplay will do this
Hi, Michael,
Thanks for your reply. I found this function in the document. It took me quite a while to figure out how to do it. The following is my code to set a model of a given name active:
Public int activateModel
char *modelName // the name of the model
char cellName[MAX_CELLNAME_LENGTH];
char cellDscr[MAX_CELLNAME_LENGTH];
MSWChar mdlName[MAX_CELLNAME_LENGTH];
int rs = SUCCESS;
DgnIndexIteratorP dgnIdxIterP;
DgnIndexItemP dgnIdxItemP;
DgnModelRefP modelRef;
ModelID iModelID;
DgnFileObjP fObjP = mdlDgnFileObj_getMasterFile();
/* Creates an iterator object that is used to process all models in the DGN file */
dgnIdxIterP = mdlModelIterator_create(fObjP);
// Create a model iterator: each cell is a model in a cell lib
dgnIdxIterP = mdlModelIterator_create (fObjP);
mdlModelIterator_setAcceptCellsOnly (dgnIdxIterP, TRUE);
/* Advances the iterator object through each model */
dgnIdxItemP = mdlModelIterator_getNext (dgnIdxIterP);
while (dgnIdxItemP)
{ // Get model name, i.e. the cell name.
mdlModelItem_getName (dgnIdxItemP, mdlName, MAX_CELLNAME_LENGTH);
mdlCnv_convertUnicodeToMultibyte (mdlName, -1, cellName, MAX_CELLNAME_LENGTH);
strpspc (cellName);
if ( 0 == strcmp ( modelName, cellName ))
{ // found the model
iModelID = mdlModelItem_getModelID(dgnIdxItemP);
mdlModelRef_createWorking (&modelRef, fObjP, iModelID, TRUE, TRUE);
if ( SUCCESS != mdlModelRef_activateAndDisplay (modelRef) )
rs = ERROR;
else
break;
return rs;
} // end of activateModel()
Any better suggestion?
You don't need to iterate the DGN file …
/** --------------------------------------------------------------------+ | | function name: models_activate | | | description: Activate the named model | | | returns: TRUE on success | | +--------------------------------------------------------------------- */ BoolInt models_activate ( LPCWSTR modelName // => Activate this model ) { BoolInt activated = FALSE; MSWChar activeName [MAX_MODEL_NAME_LENGTH]; mdlModelRef_getModelName (ACTIVEMODEL, activeName); if (0 == wcscmp ((MSWChar*)modelName, activeName)) { activated = TRUE; } else { DgnFileObjP dgnFileObj = mdlModelRef_getDgnFile (ACTIVEMODEL); DgnModelRefP modelRef = NULL; if (SUCCESS == mdlModelRef_createWorkingByName (&modelRef, dgnFileObj, modelName, TRUE, FALSE) && SUCCESS == mdlModelRef_activateAndDisplay (modelRef)) { // The following test is implemented in an unpublished function. It's // included because of uncertainty about the lifetime of a modelRef in // some earlier versions of MicroStation //ASSERT (mdlModelRef_modelsAreSame (modelRef, ACTIVEMODEL)); ASSERT (models_areSame (modelRef, ACTIVEMODEL)); activated = models_areSame (modelRef, ACTIVEMODEL); } FREE_WORKINGMODEL (modelRef); } return activated; }
and just in case you will need the model from a different file, those 4 lines are the 'easy' way, if you don't need the modelref for anything else
sprintf(command, "newfile \"%s\"", dgnName);
mdlInput_sendKeyin(command, TRUE, INPUTQ_EOQ, NULL);
sprintf(command, "model active \"%s\"", modelName);
HTH Michael
