When I Keyin the command "Modify Text" it brings up the "Change Text Attributes" dialog box. However When I run a Microstation Basic Macro It doesn't bring up the dialog box until I exit the Microstation basic Macro Selector or I run the macro a second time from the keyin line. Is there something else I need to do within my macro to get it to show the "Change text Attributes" Box every time, immediately?
kingkat said:When I run a Microstation Basic Macro
Please don't double-post.
Prefer VBA to BASIC. You can record a VBA macro just as easily as a BASIC macro. VBA help is bigger and better than BASIC help. There is no BASIC Forum, but the VBA Forum is full of VBA enthusiasts.
The Programming Forum is the lair of MDL developers.
