IMPORTANT INFORMATION: This forum is archived
This forum is archived in read-only mode, meaning you cannot create new threads or post replies to previous threads here (however, you can still search them to find information from past discussions). Topics originally intended for this forum should now be posted in the most applicable community forum identified below:
MicroStation Programming: For discussions, ideas, and other information about developing with MicroStation development tools, any MicroStation SDK, and MicroStation VBA.
ProjectWise Programming: For discussions, ideas, and other information about developing with any ProjectWise SDK.
Geospatial Programming: For discussions, ideas, and other information about developing with any Geospatial API, SDK, and toolkit.
Before starting a new thread, please refer to the MicroStation Programming forum best practices. Also, please include the following in your post:
  • The version (i.e. v##.##.##.##) of the Bentley product(s) you are using
  • The operating system (including service packs) that you are using on your workstation
  • The basic hardware configuration for the workstation you are using (e.g. CPU, RAM, graphics card, etc.)
You are not required to be a Be Communities member to read public postings, but you do have to be a member and signed in to start a new thread or reply to an existing one.
If you are not currently a Be Communities member, joining is easy -- see Getting Started for more information regarding this. After you join and sign in, edit your profile and then start connecting with others in your profession.
Should you have any questions specifically regarding Be Communities, please post those in the Be Communities Everything Else Forum. If you encounter any difficulties with joining or signing in, please let us know.
