Greetings all.
I am trying to extract the contents from the "%userdomain%" windows variable for use in an MDL application, but I
am not having any luck.
I tried to set a new MS config variable....
_USERDOMAIN = $(%userdomain%)
this gave me "%userdomain%" as the contents of the new variable.
I have tried using "mdlSystem_getConfigVar" passing in "userdomain" or "%userdomain%" but neither worked.
Any help is appreciated!
Bert
Bert ...
Bert Fegyverneki: I am trying to extract the contents from the "%userdomain%" windows variable for use in an MDL application. I tried to set a new MS config variable.... _USERDOMAIN = $(%userdomain%) this gave me %userdomain% as the contents of the new variable.
You don't need to set a MicroStation config. variable because MicroStation will interpret a system environment variable. The only time it won't do this is when you define a config. variable having the same name as an environment variable, which hides the system variable.
The variable's name is userdomain, not %userdomain%. The percent symbols are meaningful only to Windows Explorer.
Bert Fegyverneki: I have tried using "mdlSystem_getConfigVar" passing in "userdomain" or "%userdomain%" but neither worked.
mdlSystem_getConfigVar doesn't exist: I assume you mean mdlSystem_getCfgVar. Can you show us a code sample?
mdlSystem_getConfigVar is not as useful as mdlSystem_getExpandedCfgVar, which expands config. variables recursively:
char* p = mdlSystem_getExpandedCfgVar ("MS_RFDIR"); if (p) { mdlOutput_messageCenter (MESSAGE_DEBUG, "MS_RFDIR expanded (click to see value)", p, FALSE); free (p); }
