TextNodeElement Read Only Property
This question is spawned off from the http://communities.bentley.com/Products/MicroStation/MicroStation_-_all_pre-V8_versions/f/142/t/38062.aspx question of text ranges and view dependent versus independent. Additionally it may provide a sample to the previous question in this vba forum.
Now to the question. How to set the textnodeelement to dependent\independent if the property is read only? I can record a macro using the Selectby Attributes and it will let me change the property but the following code is cleaner but will not work on the text nodes (it does on just text). Just curious and learning.
Sub scanTextDep()
Dim oElEnum As ElementEnumerator
Dim oElScan As ElementScanCriteria
Dim oele As Element
Dim userTextDep As Boolean
' True makes all Dependent text independent
' False makes all Independent text dependent
userTextDep = False
Set oElScan = New ElementScanCriteria
oElScan.ExcludeAllTypes
oElScan.IncludeType (msdElementTypeText)
oElScan.IncludeType (msdElementTypeTextNode)
On Error Resume Next
Set oElEnum = ActiveModelReference.Scan(oElScan)
While oElEnum.MoveNext
Set oele = oElEnum.Current
If oele.IsTextElement Or oele.IsTextNodeElement Then
oele.AsTextElement.IsViewIndependent = userTextDep
oele.AsTextNodeElement.IsViewIndependent = userTextDep ' error here on node property
End If
oele.Redraw msdDrawingModeNormal
oele.Rewrite
Wend
End Sub
 Here is the recorded macro that works.
Sub Macro1()
Dim startPoint As Point3d
Dim point As Point3d, point2 As Point3d
Dim lngTemp As Long
MsgBox ("This will make all text view dependent")
' Start a command
CadInputQueue.SendCommand "MDL SILENTLOAD SELECTBY dialog"
CadInputQueue.SendCommand "DIALOG SELECTBY "
' Set a variable associated with a dialog box
SetCExpressionValue "selectorGlobals.typemask[0]", 5009, "SELECTBY"
SetCExpressionValue "selectorGlobals.typemask[1]", -1223, "SELECTBY"
SetCExpressionValue "selectorGlobals.typemask[2]", -30, "SELECTBY"
SetCExpressionValue "selectorGlobals.typemask[3]", -1, "SELECTBY"
SetCExpressionValue "selectorGlobals.typemask[4]", -1, "SELECTBY"
SetCExpressionValue "selectorGlobals.typemask[5]", -65, "SELECTBY"
SetCExpressionValue "selectorGlobals.typemask[6]", -257, "SELECTBY"
SetCExpressionValue "selectorGlobals.typemask[7]", -1, "SELECTBY"
SetCExpressionValue "selectorGlobals.typemask[0]", 5073, "SELECTBY"
SetCExpressionValue "selectorGlobals.viewdependentButton", -1, "SELECTBY"
SetCExpressionValue "selectorGlobals.viewdependent", 1, "SELECTBY"
CadInputQueue.SendCommand "SELECTBY EXECUTE "
Dim modalHandler As New Macro1ModalHandler
AddModalDialogEventsHandler modalHandler
' The following statement opens modal dialog "Alert"
CadInputQueue.SendCommand "MODIFY TEXT "
SetCExpressionValue "tcb->msToolSettings.changeText.viewind", 1, "MODIFY"
point.X = startPoint.X + 7.350986
point.Y = startPoint.Y - 16.868578
point.Z = startPoint.Z
CadInputQueue.SendDataPoint point, 1
CadInputQueue.SendCommand "MDL UNLOAD SELECTBY"
RemoveModalDialogEventsHandler modalHandler
CommandState.StartDefaultCommand
End Sub
  • Here is some code I use to work around the read-only justification for text nodes, with a few minor modifications you should be able to use it for other properties as well including the view independent property. In fact, looking at it could probably be generalized to allow more general manipulation of text properties, but I was in a hurry and just modified the code from the macro recorder. Please notice the small helper function at the end. Please forgive any mistakes as this was one of the first pieces of code I wrote while learning VBA and Microstation.
    Private Sub TextNodeJust(txtNode As TextNodeElement, txtJust As MsdTextJustification)
    'Justifies a text node
        'Variables to store the current user settings
        Dim curStyle As Variant
        Dim curFont As Variant
        Dim curHeight As Variant
        Dim curWidth As Variant
        Dim curLinespace As Variant
        Dim curLineSpaceType As Variant
        Dim curInterchar As Variant
        Dim curSlant As Variant
        Dim curLinelength As Variant
        Dim curUnderline As Variant
        Dim curVertical As Variant
        Dim curViewind As Variant
        Dim curJustToggle As Variant
        Dim curJust As Variant
        'capture the users settings
        curStyle = GetCExpressionValue("tcb->msToolSettings.changeText.textstyle")
        curFont = GetCExpressionValue("tcb->msToolSettings.changeText.font")
        curHeight = GetCExpressionValue("tcb->msToolSettings.changeText.height")
        curWidth = GetCExpressionValue("tcb->msToolSettings.changeText.width")
        curLinespace = GetCExpressionValue("tcb->msToolSettings.changeText.linespace")
        curLineSpaceType = GetCExpressionValue("tcb->msToolSettings.changeText.linespacetype")
        curInterchar = GetCExpressionValue("tcb->msToolSettings.changeText.interchar")
        curSlant = GetCExpressionValue("tcb->msToolSettings.changeText.slant")
        curLinelength = GetCExpressionValue("tcb->msToolSettings.changeText.linelength")
        curUnderline = GetCExpressionValue("tcb->msToolSettings.changeText.underline")
        curVertical = GetCExpressionValue("tcb->msToolSettings.changeText.vertical")
        curViewind = GetCExpressionValue("tcb->msToolSettings.changeText.viewind")
        curJustToggle = GetCExpressionValue("tcb->msToolSettings.changeText.just")
        curJust = GetCExpressionValue("tcb->textStyle.just")
        'Modify the users settings to ensure only the justification change is made
        SetCExpressionValue "tcb->msToolSettings.changeText.textstyle", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.font", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.height", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.width", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.linespace", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.linespacetype", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.interchar", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.slant", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.linelength", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.underline", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.vertical", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.viewind", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.just", 0, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.just", 1, "MODIFY"
        SetCExpressionValue "tcb->textStyle.just", txtJust, "MODIFY"
        'Make the justification change
        CadInputQueue.SendDataPoint MidPoint3d(txtNode.Range.Low, txtNode.Range.High)
        'reset the user settings
        SetCExpressionValue "tcb->msToolSettings.changeText.textstyle", curStyle, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.font", curFont, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.height", curHeight, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.width", curWidth, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.linespace", curLinespace, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.linespacetype", curLineSpaceType, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.interchar", curInterchar, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.slant", curSlant, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.linelength", curLinelength, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.underline", curUnderline, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.vertical", curVertical, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.viewind", curViewind, "MODIFY"
        SetCExpressionValue "tcb->msToolSettings.changeText.just", curJustToggle, "MODIFY"
    End Sub
    Public Function MidPoint3d(pt1 As Point3d, pt2 As Point3d) As Point3d
    'Returns the midpoint between two points
        MidPoint3d = Point3dFromXY(pt1.X - pt2.X, pt1.Y - pt2.Y)
    End Function
  • Thank you for the reply and the code. It still seems Bentley should allow this view property to be set in the vba similar to the text.
Reply Children
