In respect to Set oAttachments = ActiveModelReference.Attachments, how do you select a specific reference file with this command? I want to copy/use the clipping properties of an existing reference file. Also at a later date, I would like to pick specific reference files to turn on or off levels. Looking through all the threads, I can only find mass reference file manipulation. The code for clipping to a shape looks quite complicated.
Thank you
I'm in v8i, so I can't verify stuff for 2004, but here's a good start:
Dim oAttachment as Attachement ... For Each Attachment in ActiveModelReference.Attachments you can get: Attachment.Name, Attachment.Number, Attachment.Description, Attachment.Path (verify term with help)
Then you can use this information to choose: ActiveModelReference.Attachments(Name or Number) to manipulate.
--Robert
Hello Robert,
I'm somewhat confused. I know what reference file I want to copy. Do I need to run the For Each statement so the code will recognize the file given or is it just for information?
When I:
Set oAttachments = ActiveModelReference.Attachments(copyRefFileName) 'copyRefFileName is referenced from an Excel cell
it gives me an error ActiveModelRefen...=<This operation cannot be completed. Possible cause:...
This is the code i'm trying
Dim oAttachments As Attachments Set oAttachments = ActiveModelReference.Attachments(copyRefFileName) Copy oAttachments CadInputMessage.Keyin , dx = 0, 0 CadInputMessage.Keyin , dx = 0, 0 ' Reference a model from another file Dim oAttachment As Attachment Set oAttachment = oAttachments.AddCoincident(refFileName, modelName, LogicalName, Description)
klauden: Dim oAttachments As Attachments Set oAttachments = ActiveModelReference.Attachments(copyRefFileName)
ActiveModelReference.Attachments is plural — there may be many attachments. You want just one attachment. Try this …
Dim oAttachments As Attachments Set oAttachments = ActiveModelReference.Attachments(copyRefFileName) Dim oAttachment As Attachment Set oAttachment = Attachments (copyRefFileName)
klauden: Copy oAttachments
Copy oAttachments
It's not clear what you expect that line to do. When you copy something, you need both a source and a destination.
In the vba editor when I type in ActiveModelReference.Attachments(, it gives me the hint that I need to enter the name or number of the attachment. Please note that the name is not the file name or the logical name. So if you are trying to use the reference file name to find your attachment you may need to loop through the reference files until you find the correct attachement (attachment.filename = xxx). Once you get the attachment number, then you can continue doing what you need to.
(Again, please note that I'm in v8i SS1, not 2004. I don't know what has and has not changed.)
Okay guys,
Robert must be correct in that the name being asked for by ActiveModelReference.Attachments is not the file name. I found that using:
Set oAttachments = ActiveModelReference.Attachments.FindByLogicalName("copyRefFileName") works until I get to trying to reattach it.
The new code as is follows:
Dim oAttachments As Attachments Set oAttachments = ActiveModelReference.Attachments.FindByLogicalName("copyRefFileName") Dim oAttachment As Attachment Set oAttachment = oAttachments Set oAttachment = oAttachments.AddCoincident(refFileName, modelName, LogicalName, Description)
I tried Set oAttachment = oAttachments.FindByLogicalName("copyRefFileName") with no luck...
It's failing at the last line of code included.
Run-time error '91' Objct variable or With block variable not set
Any ideas?
I think I am so close to getting this to run I can smell it.
Thanks!
Remember that the command is "Find By Logical Name". So when you add your new attachment, make sure you specify a logical name. (if you're worried about conflicts, you could put the date or time into the logical name.) Then you can use this logical name to find the correct attachment.
Yes I have a cell with a new logical name and a cell for the description for the reattached file. It seems to drop the link for the given file name or number when I set:
It seems I need a wildcard statement or something to retain the value of the given file name or number in:
Is there such animal?
Thank you!
I would expect to do something like this:
Sub TestCopy() Dim NewAttachment As Attachment Set NewAttachment = CopyRefFile("aa", "bb") MsgBox "logical name = " & NewAttachment.LogicalName & " file name = " & NewAttachment.DesignFile.FullName End Sub
Function CopyRefFile(OriginalLogicalName As String, NewLogicalName As String) As Attachment Dim oAttachment As Attachment Dim oAttachment2 As Attachment Dim oFullName As String Dim oDescription As String Set oAttachment = ActiveModelReference.Attachments.FindByLogicalName(OriginalLogicalName) oFullName = oAttachment.DesignFile.FullName oDescription = "New " & oAttachment.Description Set oAttachment2 = ActiveModelReference.Attachments.AddCoincident(oFullName, vbNullString, NewLogicalName, oDescription) Set CopyRefFile = oAttachment2 End Function
Thanks Robert!
Still having issues mainly because the code is in a loop, I condensed it down to this:
Set oAttachment = ActiveModelReference.Attachments.FindByLogicalName(copyRefFileName).Copy
oAttachment.Reattach refFileName, refModelName
Now I'm just down to changing the reattached file's (refFileName) logicalname and description. Can't this be done in the last string while reattaching?
This was my test routine that worked:
Sub test2() Dim oAttachment As Attachment Set oAttachment = ActiveModelReference.Attachments.FindByLogicalName(oOldLogicalName).Copy oAttachment.LogicalName = oNewLogicalName Set oAttachment = oAttachment.Reattach(NewFileName, vbanull) End Sub
Thank you, thatnk you, thank you Robert and Jon!!!!!!
It works!!!
I really appreciate the help of all you!
