I sure hope this is the correct Form to post this on ? If not plese, please let me know where to put the question. If I ever get this completed it would save me a lot of time, opening and closing drawings with those attributes set correct.
Attached are two attempts to make a completed macro First VBA and then even a Basic one. They both failed the same way. The did not pickup the [Apply] button when pressed with the mouse during the recording and they did not pick up the [X] Close. I am attaching the screen shot with hopes of getting some assistance on this on going problem.
12:35 PM 5/5/2011 Set Attributes Select BoxSub Macro1()' 05/05/11 - Tried again to set "Settings, View Attributes, DataFields ON, LineWeights Off, Press Select and then close"' The record dose not pickup the select and the close ? Dim startPoint As Point3d Dim point As Point3d, point2 As Point3d Dim lngTemp As Long
' Start a command CadInputQueue.SendCommand "DIALOG VIEWSETTINGS TOGGLE"
' Set a variable associated with a dialog box SetCExpressionValue "msDialogState.viewSettingsP->view", 0, "MGDSHOOK"
SetCExpressionValue "msDialogState.viewSettingsP->flags.ed_fields", 1, "MGDSHOOK"
SetCExpressionValue "msDialogState.viewSettingsP->flags.line_wghts", 0, "MGDSHOOK"
CommandState.StartDefaultCommandEnd Sub
I am unable to get the Apply button into the macro and the [X] close buttonCould I get some help?I even went back and tried making an old Basic Macro with the same results. The DataFields are checked on and the LineWeights are checked off, but I still have to press [Apply] and then [X] close?
' Set Datafields on, Line Weights off
Sub main Dim startPoint As MbePoint Dim point As MbePoint, point2 As MbePoint
' Start a command MbeSendCommand "DIALOG VIEWSETTINGS TOGGLE"
' Set a variable associated with a dialog box MbeSetAppVariable "MGDSHOOK", "msDialogState.viewSettingsP->view", 0&
MbeSetAppVariable "MGDSHOOK", "msDialogState.viewSettingsP->flags.ed_fields", 1&
MbeSetAppVariable "MGDSHOOK", "msDialogState.viewSettingsP->flags.line_wghts", 0&End Sub
Rather than using the View Attributes dialog, you can use this keyin string:
set ed off;set weight off; selview 1;update 1
If you want to add it to a BASIC macro, add this:
MbeSendKeyin "set ed off;set weight off; selview 1;update 1"
Inga, Thank you for the Tip, I saved it with all my notes I am keeping on MicroStation Information.
RJB Phillips III - Praise the Lord for His Mercy and Grace
