I want to run vba routine by giving parameters also. Is it Possible ? (microstation 8.1/8.5 vba)e.g.,Public Sub ShowFea (intScale as Integer, lngFeaCode as long) 'todo: ....End Subi want to run it by writing following command:vba run showFea (1,2002)
Unknown said:I want to run VBA routine by giving parameters
Yes: the MicroStation VBA KeyinArguments Property. Search for KeyinArguments in VBA Help for examples.
However, it is different than the standard arguments of a sub or function. There are no parenthesis or type declarations of the arguments.
Here is an example:
Public Sub Scal()
On Error GoTo Handle_Error
' sets the appropriate cell scale factor (as=)
' If "yes" is passed, then it uses the active
' drawing scale... if "no", then as=1
Dim dblScale As Double
Dim strApplyScale As String
strApplyScale = KeyinArguments
If strApplyScale = "no" Then
'set pattern scale = 1
CadInputQueue.SendCommand "ps=1"
'set terminator scale = 1
CadInputQueue.SendCommand "ts=1"
'set cell scale = 1
CadInputQueue.SendCommand "as=1"
'turn off linestyle scale
SetCExpressionValue "tcb->lineStyle.modifiers", 0&, "LSTYLE"
ElseIf strApplyScale = "yes" Then
'read current drawing scale
dblScale = DrawingScaleFactor
'set pattern scale to drawing scale
CadInputQueue.SendCommand "ps=" & CStr(dblScale)
'set terminator scale to drawing scale
CadInputQueue.SendCommand "ts=" & CStr(dblScale)
'set cell scale to drawing scale
CadInputQueue.SendCommand "as=" & CStr(dblScale)
'set linestyle scale and enable
SetCExpressionValue "tcb->lineStyle.scale", dblScale, "LSTYLE"
SetCExpressionValue "tcb->lineStyle.modifiers", 1&, "LSTYLE"
' 'multiply the text height by this factor for symbol font points
' CadInputQueue.SendCommand "tx=*" & CStr(dblScale)
End If
Exit_Scal:
Exit Sub
Handle_Error:
LogError "[IDS]mBarmenu - Scal"
GoTo Exit_Scal
End Sub
thank you very much
Thanks Sir. Best regards
