When I Keyin the command "Modify Text" it brings up the "Change Text Attributes" dialog box. However When I run a Microstation Basic Macro It doesn't bring up the dialog box until I exit the Microstation basic Macro Selector or I run the macro a second time from the keyin line. Is there something else I need to do within my macro to get it to show the "Change text Attributes" Box every time, immediately?
kingkat said:When I run a Microstation Basic Macro
Prefer VBA to BASIC. You can record a VBA macro just as easily as a BASIC macro. VBA help is bigger and better than BASIC help. There is no BASIC Forum, but this Forum is full of VBA enthusiasts.
Try this keyin:
mdl load modify; modify text
Good luck, Roland
Roland
V8i SS4 v.08.11.09,829AECOsim BD V8i
Thanks to all. I found a work around that satisfied me.
Hi together, Hi kingdat
can u provide us how the workaround looks like.
i cannot show it up also by using keyin in macro. Seems to be, because the dialog is modul and waits for input.
