VBA Batch process
Wrote this vba script and using it on 1 file works with just the vba,
however when I ran it using several sheets using the batch process it will go from sheet to sheet and I guess it applies the command however it will not save the settings, and if I try just 1 sheet on the batch process it will turn off the levels but will not allow me to save the settings. Even if I manually save settings when I log back into the drawings the levels are on... if I just manually turn a referenced level off and save the settings it will keep it even after exiting and going back into the drawing. this is the script,,, any suggestions on what could be wrong?thanks
Public Sub LevelOff()
Dim att As Attachment, filename As String
filename = "D468620-Topo_05.dgn"
For Each att In ActiveModelReference.Attachments
If StrComp(att.AttachName, filename, vbTextCompare) = 0 Then
att.Levels("DEC_Topo_Riser").IsDisplayed = False
att.Levels("Aerial Survey_Control Points").IsDisplayed = False
att.Levels("Topo_Vegetation").IsDisplayed = False
att.Levels("Topo_Roadway Notes").IsDisplayed = False
att.Levels("Topo_NonHighway Improvements").IsDisplayed = False
att.Levels("Design_EX_Roadway Notes").IsDisplayed = False
att.Rewrite
End If
Next att
End Sub
Use this command:
CadInputQueue.SendCommand "Save Settings"
If you're going through Microstation, the command would be:
CadInputQueue.SendCommand "FileDesign"
If you are using vba, you might as well use the vba command which is
SaveSettings
That's hard!
--Robert
Robert,
Using this example and solution of SaveSettings will not hold the save settings in the file after the vba is run, even a manual save settings does not work. I've tried running it both in MicroStation batch process and running just the vba.
Any clues?
This is one of my older routines... I see a AttachedFile.Levels.Rewrite command. I wonder if this is the issue. Also, I though of ActiveDesignFile.Save as another possibility.
Sub AllReferenceLevelsOn() Dim Level As Level Dim Attachment As Attachment Dim I As Integer
'Each Attachment For Each Attachment In ActiveModelReference.Attachments DisplayLevels Attachment Next RedrawAllViewsEnd SubPrivate Sub DisplayLevels(AttachedFile As Attachment) Dim Level As Level Dim Attachment As Attachment Dim I As Integer 'Turn on all levels in this attachment If Not (AttachedFile.IsMissingFile) Then For Each Level In AttachedFile.Levels If Not (Level.IsDisplayed) Then Level.IsDisplayed = True If Level.IsFrozen Then Level.IsFrozen = False Next For I = 1 To 8 If ActiveDesignFile.Views(I).IsOpen Then For Each Level In AttachedFile.Levels If Not (Level.IsDisplayedInView(ActiveDesignFile.Views(I))) Then Level.IsDisplayedInView(ActiveDesignFile.Views(I)) = True Next End If Next AttachedFile.Levels.Rewrite End If 'Do it again for each nested reference in this attachment For Each Attachment In AttachedFile.Attachments DisplayLevels Attachment NextEnd Sub
