Dear All,
How to find the direction of the linestring . I have tried the code available in this link http://debian.fmi.uni-sofia.bg/~sergei/cgsr/docs/clockwise.htm , but it failed.
My issue I need to compare 2 elements whether it belongs to same direction ie., Start point of the element in the 2 elements is in the first vertex or not in the vertex list.
Can any body help me to resolve this issue. I would appreciate is some body send me the code snippet.
K.JAYAKUMAR
Unknown said:I need to compare 2 elements whether it belongs to same direction
Consider the following VBA data types …
Ray3d may be useful to you, because it has a direction. Construct two Ray3d objects from the start and end points of each of your two lines. Now you have two direction vectors that you can compare.
Use Matrix3dFromRotationBetweenVectors to calculate the angle between the vectors. Read the notes about that method in VBA help …
Returns a matrix representing rotation from one vector to another. In the usual case where the the vectors are neither parallel nor antiparallel, the rotation is around their cross product, which is perpendicular to their plane. If the vectors are parallel, the matrix is an identity. If the vectors are antiparallel (opposite directions), the rotation is 180 degrees around some vector chosen to be perpendicular to them.
