I use a application written in mdl witch places a dimension driven cell. The dimensions of the cell are modified before placement through a list of values chosen from a list box.
I have currently switched to V8XM, before I used my application with V8. Since my switch the application is acting strange so I think there are some issues with the code.
When recompiling the application under XM I get a number of errors stating there are some functions not available anymore.
I am searching for a technical paper, manual, sourcecode that can explain how dimension driven cells can be programmed under XM. I don't care if it is in mdl or VBA, as long as I can get my application up and running again.
Can anyone help me?
Wim Aerts
4D select
The dimension-driven design api has not changed. What functions are compiler or linker complaining about?
Sam Wilson
Hi Sam,
I get a complaint on two functions, one of them is mdlCell_getFilePosInLibrary and the other is consLGroup_readCell. Both of the functions work with filepositions in cell libraries.
Regards.
4D select nv
Wim: I get a complaint on two functions, one of them is mdlCell_getFilePosInLibrary and the other is consLGroup_readCell. Both of the functions work with file positions in cell libraries.
A cell library is a DGN file. A DGN file is a cell library. A DGN file contains models; a cell library contains cells: but a cell is a model. The difference between a cell library and a DGN file since V8.0 is the file extension.
I believe that mdlCell_getFilePosInLibrary was deprecated wtih V8.0. I can't find consLGroup_readCell in either the V7 or V8 MDL documentation.
Use something like mdlCell_findCell to determine whether a cell exists, then mdlCell_getElmDscr to get an MSElementDescr*, or mdlCell_placeCell to place the cell at a known location.
mark anderson [Bentley]
Visit me at https://communities.bentley.com/communities/other_communities/bentley_innovation/default.aspx
Mark,
Do you have a definition file for the consLGroup_... functions? I can't seem to find them anywhere. I only have a definition for my (not working) consLGroup_readCellfuntion.
