Issue: DArrays and EmbeddedArrays...
What is the maximum count of members in these arrays??  Integer maximum value is 2147483647, so maximum member index is this??
    That's right. The index and size parameters are typed as signed 32-bit
    integers. Of course, you will run out of memory long before you managed to
    insert 2 billion members into an array.
    I strongly recommend that you use std::vector.
    Sam Wilson
  • 64-bit Address Space
    Sam:
    You will run out of memory long before you managed to insert 2 billion members into an array.
    What happens when MicroStation is running in Windows 64-bit?
    Suppose your computer has 16MByte RAM running Win XP/Vista 64-bit. MicroStation supposedly will use as much RAM as it's able to grab from the operating system. Is that extra memory available to MDL applications?
    Regards, Jon Summers
    LA Solutions
    LA Solutions
Reply Children
